Wiring Audio System Separate from car electrical?
  • 3
CplCuddles
Certified Meme Warrior
Hey guys, I am getting a HO alt soon and I am wondering multiple things. 1st, Can I add in my HO with the stock? I figure no point in junking my stock alt if it helps the system. 2nd The real question, If I can indeed hookup both, Could I run my stock JUST to my vehicle and run my HO dedicated to the audio system? Then I wouldn't have to worry about my front battery dying or the vehicle electrical straining because of my audio system. Here is a crude drawing of what I am wanting to do.
As long as you have at least minimal battery in the rear... your front battery would never die while driving..
Battery is too far away= resistance is much higher in that area, therefore, all power from both alternators would be consumed because they are of higher voltage 1st.
1. Sure, it would function but it would look a little half arsed. Ideally you would use a distro block and run separate wires to each amp or...
780
The first two screws (IN+ IN-) go to the amp/radio. Second pair of screws (W+ W-) go to the woofer. Third pair of screws (T+ T-) go to the tweeter.
6
870
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
198
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
599
CplCuddles
CplCuddles
Topeka, KS
shizzzon
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
