Connecting speaker wires from amp to factory wires?
  • 1
Bmcallister
Hey guys,
I’m new to the car audio scene so bare with me, I recently got a kicker 4 channel amp that I want to use to give my kicker 6x9 lower door subs some more kick. My questions is do I have to run the speaker wire from the amp to the speakers or can I get away with connecting the speaker wires to the power outputs behind the dash. I just want to power my lower door speakers from the amp not the mid range or tweeters that are also in the door.
If I have to run the new speaker wire from the amp to the lower door subs what do I do with the power outputs behind the dash?
Thanks
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
749
Thank you for the help. Now I finally understood :) Bass working fine now :) Life back to music ;)
4
Hi @winkychevelle thanks 🙏 but I guess I have used up all inputs as I am running on 3 way so I left with the 3.5mm will look into it with the...
Bmcallister
Bmcallister
Bethlehem, pa
Bmcallister
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
