Wiring for Dash Cam
agaladari
Dubai
Hi..
I bought myself a Dash Cam, I thought I will be getting as direct cigarette lighter plug.. but instead, it came with terminal wires (12V Battery, ACC, Ground).. I don't want to hard wire the cam to the terminals, so, Can I connect this directly to Cigarette lighter plug?
Cigarette lighter plug has two wires, how to connect three wires (12V Battery, ACC, Ground) to two wires cigarette lighter (+, -) ?
Can I connect the (12V battery wire to ACC wire) and use those as positive and Ground to negative?
Thank you
You want a switched power source (only on when the key is in the run position). Your best bet is a wire tap and find a fuse that is only on with the key.
Sent from my Nexus 6P using Tapatalk
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
107
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
517
agaladari
agaladari
Dubai
ajb1205
winkychevelle
    Jun 3, 2024
