wiring subs to .1 ohm
  • 6
Ok so that diagram u showed I wouldn't have to wire them together at all? Just a +&- jumper on each sub then the other +&- to the amp? Repeat for each sub?
If you wanna use all the terminals, it gets wired like so:
Ok exactly what I was looking for, so I dont have to use any jumper wires on each coil?
Subwoofer Wiring Diagrams, One 4 ohm Dual Voice Coil (DVC) Speaker
Wire ea sub to a 2ohm load back to on set of +,and - terminals,and the amplifier bridges internally for dropping to the 1ohm load on the subs impedience.This amplifier and others like it with dual connections are made to eliminate that extra Jumper exposed wire from sub to sub
Wire to the 2ohm diagram as shown for the MTX subs on the one amplifier you have. That amp should do very well on those two subs. alpine make some...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Sell the dual 2 and get another dual 4.
Tyler24
Tyler24
Hawthorne, Nevada
04murdalanche
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
