XS Power batteries are made by XS Power. Powermaster has nothing to do with XS Power and is a completely different company. Optima is made by Johnson Controls.
Actually there are a lot of things that make XS Power Batteries different from the competition, and we will have some informative videos coming up soon to better explain this. One thing that makes XS Power batteries different is the technology used in making the batteries. Lead Tin technology is by far the leading technology in AGM batteries. The Lead Technology allows us to make the lead plates thinner and pack more plates into the cells of the battery. The more plates you have in the cells the more surface area you have in the battery.
The industry standard AH rating is the 20hr rate. Our AH rating info is on our site, so either Google wasn't looking very hard or you may have just overlooked it. I am on plenty of forums you are on and I can't ever remember you asking me what the rating is. We do not try to hide any of our ratings or info from the customers and all you had to do was ask.
FAQ’s « XS Power
The true question here though is are you wanting batteries to run fog lights and trolling motors or for car audio? I say this because AH ratings have NOTHING to do with car audio. In no way can LOW amperage pulls for HOURS be equated for HIGH amperage pulls for SHORT periods of time. Of course if you want to run your 20amp fog lights through out the night to light something up, then you need to pay attention to the AH rating, but for car audio AH means nothing.
The battery can be 500AH but if it is not able to provide the power your system needs instantaneously, then it is going to do you no good. There are specific designs for batteries to get the AH ratings up. To do this you redesign the battery's internals to limit the power output and prolong the time. Just like having 5 gallons of water in a bag. If you put a 1/2" hole in the bottom of the bag then the water can only come out of the 1/2" hole and it will take longer for the bag to drain. If you put a 2" hole in the bottom of the bag, of course the water will drain out a lot faster. If you only need a little amount of water at a time for an extended period of time then the 1/2" will be fine, but if you need need a lot of water quickly then the 2" will work better for you.
