your broken amps
got a power acoustics a3000db. hooked up backwards fried some mosfets . took it to a local guy said he could fix it witch he did not fix it and and i got it back in pieces.
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
365
515
nuttcase21
nuttcase21
buffalo, ny
quins90lac
    May 31, 2024
    May 24, 2024
