I need some help!!! Amplifier problem
Nate Fenton
I have a Pioneer GM-A5602 amp and I'm running it with a 12 inch Kenwood KFC 250watts rms and I have it bridged to 450watts rms amp. WhenI'm bumping it my amp led flashes once and cuts out and cuts back in and I don't know what's going on. I checked my fuse and my wire? I checked my remote wire and I don't know? Could you help me please? Thanks
there could be a litany of things that it could be. What does your ground look like? What is your wire gauge? (no offense by this next question) did you run your wire thru the firewall? I ask because ive seen a few installs where they have run the power wire thru the door jam and pinched it in the weather stripping. What is your gain set at?
You could also check the RCA cables, most of the time is bad cables.  Not sure if that would make the light go in and out if ur were losing signal from the RCA, also some amps when wired below there recommend ohm load will cut in and out instead of going into protect.
588
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
Here is my thought, theory. Those speakers are 80w rms. Half of that is 40w rms. Add the 40 to the 80 and you get 120w. Get an amp that is 120w...
I have 2 Sundown SA10v2 (1000w version) and just replaced my RF R1200 with a T-1500.1bd and OMG! I was considering Ampere Audio, JP23, Sundown...
Hmm. Maybe so. Ive never been more alert driving/riding than being on a Cycle man. Several think you just get on and ride away. A good set of...
26
5K
Nate Fenton
Nate Fenton
Dragonsyph
