Audio system has little sound after truck sat for 6 months
  • 2
Tidbit
Ok I have an 02 Silverado 2500hd duramax. About 2 or 3 years ago I installed power acoustic flip out touch screen head unit, clarion eq, Orion 3000 watt mono sub amp 1ohm stable, Polk audio 4 channel 250rms per channel, Polk audio component speakers front and back. System always worked great and was clear and loud as hell. Due.to engine issues it had to sit for 6 months. After fixed I noticed all audio powers up, no blown fuses, eq works but I get no sound from any source unless I turn it all the way up to 50 max vol. Sounds is.intermittant and.sounds like your.on a station that doesnt get good reception. CD,  aux port and.Btooth all the same way
 Could corrosion at my main 50 amp.fuse under good.cause this?
The clarion EQ (if you have the same one i suspect) has an input switch, make sure it's not pressed into the AUX position (can happen by accident). That would mean you'd just hear the cross-talk from the HU input.
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
209
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
Look at Recoil components front and coaxials rear. Cheap solution. The Taramps is fine, or Recoil, or blackbrick 100.4 for $69 shipped. More...
Tidbit
Tidbit
keep_hope_alive
    May 31, 2024
