03 expedition aftermarket amp and subs
  • 2
Harrymane
CarAudio.com Newbie
Hey, any one had trouble having their AM amp working on a 03 expedition Eddie Bauer? I discovered that this vehicle comes with its own subs and I would need to by pass it. Anyone can lead me to the right direction? I've tried a harness but all it did was turn the factory subs on. Which I don't want. I also tried a Line Output Converter. But no luck. Please help. And thank you.
It appears you want to add your own subs and amp and you want to totally bypass the factory subs.
One method is to physically disconnect the factory subs from the factory amp, then use your LOC on the factory sub amp output.  With this option you'll want the factory subs to be on, then when you disconnect them (unplug them and insulate any unused connectors) you will have a signal to the LOC.
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
Many whom bypass the OEM amp, tap into the harnesses there. It is all there in one spot so no need to remove panels or runners. Just Google 2017...
The Regulator for my car is built into the harness, I keep forgetting that VAG cars are fucktarded sometimes.
5
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
625
Harrymane
CarAudio.com Newbie
Harrymane
keep_hope_alive
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
