-PLEASE HELP-Whats the best way to wire amp to subwoofer
Quit calling Jeff into your lame ass garbage. You literally repeat what Moon said. You think you better than folks? You think you hurting feelings?
I made the answer better. This convo has nothing to do with you. Going back to your old self again I see..
Speaking of steak.  😂
Wire to 2 ohms. Don't clip.
End thread/
That sort of thinking is why an audio shop blew one of my subs years ago.
I was having them install a new battery, but they decided to start fiddling with my amp gain. I had it turned down to avoid over driving the sub, but they turned it up just below clipping, then blew the sub while testing. Thankfully they gave me a replacement and owned up to their mistake, but it's stuff like that that has me play it safe when giving advice.
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
952
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Waylon Daniel Eric Hagin
fithwheel
    May 16, 2024
    May 16, 2024
