Which should I purchase Skar rp2000.1 or skv2-2500.1?
2nd the adding of another d2 SA in a proper enclosure on a .5 stable amp.
don't let .5 scare you after rise you wont be loading the amp with a 1/2 ohm full tilt.
Sundown SA series are dollar for dollar some of the best subs you can buy even though i hate being a sundown nuthugger their products as well as their customer service while isnt flawless are better then most car audio manufacturers.
I did purchase directly that's the price -15% for the sale they had. They still emailed me the invoice as a receipt.
IDC at this point I have $1500 to spend. I'll figure it out.
Okay I'll take your word, even if you did buy it directly, those prices are insane.
I'd advise you to get that 270a alt /w/ an upgraded agm up front /w/ big3 and most likely some secondary agm in back if you are really going .5 on anything 2k+...
Electrical 1st
Welcome to Car audio.
Now its comin thru. See we’re not all just a bunch of trolls waiting to swarm on new folk (I hate the word noob because I’m definitely still a noob in respect to my electrical understanding).
As shredder mentioned, bigger alt will be good to have no matter what and know that it’s better on all your equipment to run a bigger amp turned down vs trying to push every watt you can out of a 1k- 1200 watt amp that is .5 ohm stable. Efficiency matters here.
Buy that 270a alt... car audio just seems to be one upgrade after another.. a Skv 2500 @ .5... meh... imo a decent 3.5k+ is in your future.
It's never enough Op
2 sa 12's can deliver if the enclosure is configured right and built correct.
What do you really think this system will achieve? 2500 @ .5...
Cone limited setups have a limit...
2 Sa12s tho?... 145+ with clamped rated power.
Once the electrical is done then focus on the little things, but understand that once electrical is done...enclosure is everything.
Jmho...
.02
orion must have some serious delays in production because a couple months ago my brother was wanting a xtr 2500 and all that was out there was priced at msrp
Repricing according to demand?.
Seems every boner is becoming more expensive anymore.
Just buy in and I'm sure you will get a good deal.
Jmho...
.02
I found a sundown dealer in Tampa that also builds boxes so I went to see him.
His opinion for my trunk is just keep the single sa12 in a 4th order bandpass box that he will build for my trunk.
Does that sound like my trunk isn't big enough for 2 sa12s or maybe he didnt realize I kinda wanted to run 2 12s vs 1 ???
We did 2 Zv4 12s on a FSD3800 in a 14 corolla years ago.
Ok cool, maybe I need give him a call to make things clear.
Other than that from what I've been reading the terramps amps are good as long as they are fed the proper power so in my case with only big 3 upgrade and a Northstar under the hood Im probably just gonna buy a soundqubed amp around 1500rms
No, get a bigger amp and a voltmeter wired into the amplifier input termainsl and turn the gain down if it's too much voltage drop.
Let's say I have a 3k w amp(not even thinking about buying that big but for instance) and that single sa12 could I have underpowered a large amp if only pushing a much smaller speaker?
Guess another way to word it would be does the speaker itself factor into how many amperes the amp pulls from my electrical system?
The CT's are nice, That Sundown is a a frik'n beast!
774
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
661
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
765
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
danielbea122
CarAudio.com Exclusive
danielbea122
Tampa
shredder2
    May 22, 2024
    May 22, 2024
