Wiring troubles and head unit issue
obv_ius
So I bought a five channel amp (Rockford fosgate r600x5) for my 4 6x9’s and a sub. My aftermarket head unit only has 4 channels. I want to add an rca out for my sub. I’ve seen line out converters, so would i need one and if so how would i go about wiring it? If there is another way to solve this issue I’d be happy to hear it.
(my amp rating is in a photo below)
My 6x9’s run 70w rms (300w peak)
Sub runs at 250w rms (500w peak)
my next issue is wiring my 4ohm 6x9’s to make a 2ohm load for each pair. I know I’d have to parallel them but the issue is that the negative and positive are already soldered (photos below). I don’t know how i need to wire them with the speaker wire to connect them to the amp because I’m not using the factory harness. I’m new to car audio and this is my first project which is why I run into so many issues. I just want to have everything in order before I take anything apart.
Why are you trying to run them at 2 ohms and not just a 6x9 per channel at 4 ohms?
You can use RCA splitters on the rear RCAs to your amps rear and subwoofer inputs. Then use an RCA bass knob to control subwoofer volume.
You could get a 7 band EQ that has 4 inputs and 6 outputs. (NVX XEQ7)
Or a headunit with 3 sets of outputs.
Which aftermarket headunit?
As it relates to the first issue, I used a Y-adapter for one set of RCA cables. That provided me with a signal for channel 5, (or another amplifier).
As it relates to your second issue, not sure why you would be concerned about the speaker's terminals already being wired positive and negative. Speaker wire - Positive to positive and negative to negative. See diagram.
23255
Let me know if I got your issues totally wrong. Just trying to help.
Would those 2 speakers now be 1 channel in the amp?
I have more questions. Would i use 1 female to 2 male rca y cable. And would i only need to do this with only one of the rear speakers?
A 5 channel amplifier only needs one set of rcas to produce 5 channels. Only reason to use two sets of rcas is if you want to have the fade option. As for the sub channel, the amp does that on it's own.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
50
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
457
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
508
569
500
obv_ius
obv_ius
California
