Help with new setup
Jerk1981
I’m about to purchase 2 dual 2 ohm Skar EVL 12” subs I’m currently using a new Crunch GP2500 watt amp on 1 12” Skar SDR I know this amp is not really even pushing anywhere near 1000w Rms so it’s not enough for those subs I’m hung between three amps CT-sounds 1500w, Skar RP-1500w & Down4sound JP 800w which dyno’s right at 1000w thanks for the help I appreciate it
You don’t have enough power with any of those amps for 2 skar evl 12s. You’ll need at least 2500 RMS or you would be better off going with lower power subs and getting full excursion. Those amps will barely move those evl 12s.
Not to mention if he's getting 2 D2 subs, he can only wire to 2 ohm or .5 (or 8, but who does that?)
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
One Of my favorite sites to gain some information over the years. Excellent! I would deff. Bookmark it!!
38
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
Jerk1981
Jerk1981
Trion ga
Slo_Ride
    May 31, 2024
