Front door speakers don’t play
  • 2
JoshuaSK27
I have an 05 Scion tC. It has a factory anp. I installed subs and an amp, and a new head unit. Also new pioneer speakers in the front doors but they do not play and are wired to head unit correctly. I’m pretty good with this stuff, so do I need to wire them to factory amp as well or bypass it or what? Help! I’m driving a lot rn and I need my music to sound 🔥🔥🔥
Ha! I'm with you there. Did you use a wiring harness to avoid cutting wires from the OEM harness? If yes, then make sure the blue wire from the radio connects to that harness' blue wire, just like the sub amp.
Actually I just took my drivers seat out and there are two harnesses connected under the seat but no amp…. The wires are correct on the harness. They are all labeled. Wtf could it be? I put super nice mids/tweeters in both doors. I have bass, my rear speakers, and the tweeters in the upper part of the door work so w. T. Fffffffffffffffff????????
And yes to the wiring harness. Never cut factory wires lol
Are the underseat harnesses plugged to each other or just dangling? Post a pic.
The harnesses are connected fine. I took the door panel off. Look at what we have and tell me what to do. Everything in my brand new head unit is good.
  • IMG_9086.MOV
    11.3 MB
First of all they **** me and put the wrong speakers I. My car as I paid for pioneer. Tf would I downgrade my **** for? That are 4 ohm so how should I connect them to make them work bc they are doing nada.
Yeah, these are listed as 3ohms nominal and that is why you see the 2.7ohm rating (where they can drop to). There are a number of things wrong...
954
891
JoshuaSK27
JoshuaSK27
Charleston, SC
Decebal
    Jun 10, 2024
