After Market speakers (triton) sound way too harsh
COSMICBEATS
Hey, so i recently decided i wanted to upgrade my honda stock speakers to an aftermarket brand. I have a 12 inch pioneer with a built-in amp which sounds amazing. My honda stock speakers sounded fine the only issue was i wanted to be able to play it a bit louder than what it was at before without it becoming distorting. After going to an audio shop the guy recommended me the Triton SQ 522 series. Right off the bat after installation i noticed how harsh these speakers were. Any song would have my ears ringing. After touching the settings i was able to turn the gain down but they still have that harshness to them. What should i do, i spent a lot of money on this just to not be satisfied ☹️
Below are my amp settings for the sub and the speakers
i’m also in a 2018 Honda civic si coupe
Pop open the crossover module and try the -3 and -6db switches and see if that doesn't tame things a little. I'd also think you can turn down the crossovers on your amp some. 120hz is too high. Play some bass heavy music and turn those down slowly and either watch the cones or listen for signs of mechanical stress on the low notes then turn it back up a touch after you've reached that point.
where are the cross over modules located ??
That might depend on the head unit. Some can use a 5 amp fuse, some a 10amp, some a 15amp fuse (if / depending on how much it's powering the...
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
151
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
278
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
149
COSMICBEATS
COSMICBEATS
Tallahassee, FL
R@kshasa
    May 23, 2024
    May 22, 2024
