After Market speakers (triton) sound way too harsh
COSMICBEATS
Hey, so i recently decided i wanted to upgrade my honda stock speakers to an aftermarket brand. I have a 12 inch pioneer with a built-in amp which sounds amazing. My honda stock speakers sounded fine the only issue was i wanted to be able to play it a bit louder than what it was at before without it becoming distorting. After going to an audio shop the guy recommended me the Triton SQ 522 series. Right off the bat after installation i noticed how harsh these speakers were. Any song would have my ears ringing. After touching the settings i was able to turn the gain down but they still have that harshness to them. What should i do, i spent a lot of money on this just to not be satisfied ☹️
Below are my amp settings for the sub and the speakers
i’m also in a 2018 Honda civic si coupe
Pop open the crossover module and try the -3 and -6db switches and see if that doesn't tame things a little. I'd also think you can turn down the crossovers on your amp some. 120hz is too high. Play some bass heavy music and turn those down slowly and either watch the cones or listen for signs of mechanical stress on the low notes then turn it back up a touch after you've reached that point.
where are the cross over modules located ??
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
173
That might depend on the head unit. Some can use a 5 amp fuse, some a 10amp, some a 15amp fuse (if / depending on how much it's powering the...
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
153
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
172
COSMICBEATS
COSMICBEATS
Tallahassee, FL
R@kshasa
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
