Sterio not working
94 dodge
Shop
Hi I have a 94 dodge regular cab pickup. I had pioneer speakers put in it a few years ago along with a basic single din kenwood radio. I just restored the interior and found
there are 2 more speakers behind the seats so I put new pioneer speakers there and found out they weren’t wired to the radio. I hooked them up and they worked for a few days and then my radio started flashing protect. I did some research and figured I had a short. I unhooked the speakers that I put in behind the seats and and the radio stopped working all together. I have power to the radio but it won’t turn on. Just curious if someone has run into something similar to this?
thanks
I have never heard of a radio having that protect feature. Did it say protect on the screen?
Anyways, I assume you have checked the fuses on the radio. Did you also make sure the red wire was getting power. Both Red and Yellow wires need power for radio to function.
Yea it would just flash protect on the screen. Both the red and yellow have power. All the fuses were good even the one on the back of the radio. I even had another radio lying around that I plugged into it and still nothing.
Figured it out. For some reason my rca cables would work in everything but the new head unit. I quickly tried a spare set, and that fixed the problem.
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
94 dodge
94 dodge
Shop
