Alpine KTA-450 Amp Buzzing
monkeyshiner
USA
I have the Alpine Power Pack amp KTA-450. It produces a buzzing sound through the tweeters when the key is in the ignition position with the engine off and while the engine is running but NOT while the key is in the ACC position. I've disconnected the rca cables from the amp with the same results. Power and ground are connected direct to the battery. I cant find a fix.
Try grounding somewhere else. Maybe the power and ground wires are too close to each other. You could try an RCA ground loop if that doesn't work.
227
529
So far I have bought Kicker CWRT8D4 Subthump underseat enclosure for 8 LoopBack Harness from AIS 8 gauge Kicker wiring kit (Will run two 8 gauge...
13
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
monkeyshiner
monkeyshiner
USA
Bobbytwonames
    May 19, 2024
    May 19, 2024
