140db With Two 8's? T Line Enclosure
That's not too bad then. I was thinking I had my hopes a bit too high. I'm really curious about T Line boxes and I might just give one a shot. Don't know if I'll get the same volume, but you guys are all in the upper 130's to 140 so why not.
Any thoughts on the SA 8 vs X8 sound quality wise. Everyone says the X8 is more of an SPL monster than SQ. They're both in my budget so if the X8 is worth it, why not.
Did 142.3 with 2 208sq subs. Amp was CT2200.1 @2 ohms.
---------- Post added at 11:01 AM ---------- Previous post was at 11:00 AM ----------
Stang Tline box
Stang Tline box
Perfect. That's what I was looking for. I've been talking with Chris about a box for a couple is SA8's and I wanted to know where they hit. How clean does your sub stage sound in that setup?
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
The preamp input on most amps is 10-20k ohms, so you don't really lose voltage. I've run plenty of systems off 2v preamps with no problems.
5
SimulatedZero
SimulatedZero
Tallahassee, Florida
SimulatedZero
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
