'75 Cadillac Setup
Jesus crap you guys are messing with my head...
Those Fi subs look... fscking... amazing!!
The car does have the trunk space... it isn't like I am stuffing dead-bodies in there a la Mafia.
Another question, what company would you call "good to excellent" regarding component speakers?
Any preferences?
Thanks!
I am still trying to figure out what the "Big 3" are.
Alternator... cables... smelly tree?
Checking out the Eclipse head units now...
Although I rather spend the $$ upfront for a very good HU.
Much thanks bud![/quote
look into some touch screen hus. always cool to have and alot have very nice sq and high voltage rca outputs
Here is what I suggest you do scrap that idea of dash speakers use some of your budget and build door pods throw a nice three way in there. Then spend some more to upgrade your electrical and deaded that bad boy up.HU
CDA-9887 - Alpine CD/MP3/WMA/AAC In-Dash Receiver $329.99
Comps
CSX 465.20 - Rainbow CSX 6.5" 3-Way Component System $309.99
Amp for Comps
KAR 400.4 - ARC Audio 4 Channel 400 Watt Amplifier $269.99
Subs
Two SE10 - RE Audio 10" (Dual 4 Ohm) $239.99 ea
Sub amp
MD-1D - US Amps 1 Ch MD Series Amplifier $449.99
*Prices were quoted from woofersetc.com so prices may vary*
You still need RCA's,Alt,Enclosure,Deadner,Wiring and etc.
FTW!!!
Door pods!
Ok, dumb question:
If I ditch the dash speakers...
The I'd have four in the doors... and two in the rear deck?
Place four in the rear deck?
Ditch those?
Just asking... not sure what would be better.
**** I am PUMPED!!
I WANT THIS ALREADY!
LoL
Most dont run rear speakers leaving the cutouts empty to let more bass into the cabin. Take your time though and do as much research as you can. There is so much to learn.
FTW!!!Door pods!
Ok, dumb question:
Ditch those?
**** I am PUMPED!!
LoL
Yeah get your doors fiberglassed and make custom speaker enclosure in your door. that caddy probably has 3",4x6's or 5x7's speakers wich is not going keep up with a pair of subs and give you the type of Kickazz sound you say you wanted. I suggest you really reasearch these car sudio terms to understand fully what you need and do not need. You don't need a bunch of speakers to keep up with a pair of 10's. A pair of well powered comps will do just fine up front in the doors with the 10's in the trunk. if you want another set of speakers for the back I would suggest a pair of coaxials ran off the HU
Cool cool! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'll organize my thoughts, and post more soon.
Thanks a ton for all the help so far!!
Will definitely update everyone here with the project (plus my 1,000 questions).
w00t w00t! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks!
The "Big 3" is just a simple wire upgrade under the hood. Alternator + to battery +; Battery ground(-) to Chassis ; Chassis to engine(also ground)
This should be quite easy on an older car like that
I am sure that caddy has something small in the dash like 3",4",4x6's,4x10's. So to replace that with a pair of coaxials would be silly IMO but to each is own. I think you need to read more threads especially the stickies to get a better understanding of what certain terms mean as well as get a feel for what you will need and will not need.
Comps
Amp for Comps
Subs
Sub amp
I like this. The only alternatives I would consider are an Image Dynamics subwoofer, an IDQ, or an Si Mag v4, something along those lines. And I might consider stepping up to the Rainbow Germanium's, I've heard the step up is well worth it.
In addition, for a correct staging of sound, you don't require rear speakers. Use a 3 way setup in the front of the vehicle, which emulates listening to music from in front of you. Music, in 99% of cases, is not surround sound, unless you are watching movies, in which case you do not need a rear fill.
DO NOT use a 3 way system for your front soundstage, it's going to be too difficult to setup correctly unless your installer is world class.
HU - whatever you want
Comps - PPI 365cs $135 shipped on ebay through SonicElectronix.com
http://cgi.ebay.com/PRECISION-POWER-PPI-356CS-6-5-CAR-COMPONENT-SPEAKERS_W0QQitemZ300366124106QQcmdZViewItemQQptZCar_Speakers?hash=item45ef37544a#ht_1979wt_1165
Component amp - Sundown SAX100.4 $365
http://cgi.ebay.com/Sundown-Audio-SAX-100-4D_W0QQitemZ180421137139QQcmdZViewItemQQptZCar_Amplifiers?hash=item2a01f012f3#ht_1133wt_1165
Sunwoofer amp - Sundown Audio 2000d $599 - this amp will smash windows out of cars
http://cgi.ebay.com/Sundown-Audio-SAZ-2000d-amplifier-NIB-with-warranty_W0QQitemZ250514970410QQcmdZViewItemQQptZCar_Amplifiers?hash=item3a53db172a#ht_550wt_1165
Subs are personal preference, Check out SSA Icons, JL W7s, FI Q, etc. etc. etc. that amp will power anything you throw at it
$150-$200 on 0/1 wiring
$200 get a Chevy alternator off of one of the newer HD trucks and you'll have ~200 amps
$300+ http://www.sounddeadeningshowdown.com
$$$$$ a GOOD installer, crappy speakers installed well sound better than great speakers installed poorly
SlipAngle, thanks for the post!
I will have those in consideration... I'm still checking to see what exactly I do with the car. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i'd run some sort of rear fill speaker in that car. the cabin space is so huge that the fronts would be kinda lost in there. you could put a pair of 6x9s back there, but make sure they are run at very low volume. you're only looking for fill, not a focal point of sound. I would agree with components up front, and a pair of 10s or even 12s would do nicely. I'm kinda wierd as in I like to get 3 or 4 8s going on and get a nice sound out of them. and I'm a huge fan of 5ch amps.
Jesus crap you guys are messing with my head...Those Fi subs look... fscking... amazing!!
Any preferences?
Fi subs are sick. the owner use to be the big cheese of.... http://www.reaudio.com
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
3K
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
620
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
943
WaterSubs
WaterSubs
Caribbean
nauc
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
