'92 Mazda 626 Single Death row build.
Proper port area will make a huge difference you almost have them breathing through a straw with your current port I would up the port area so that sub can pound like it's supposed to.
Alright, didn't think it would be a biggy, I will though.
Well, my box is 4.1 cubic feet and with a 4" hole I have to cut a bigger one to get more length.
7" is the longest I can get pre much tuned @30hz.
Looked on Torres, does anybody think I should tune to 25.27hz with a port area of 12.56" with my box volume of 4.1 cubic feet?
I probably should have more port area but I don't want to cut a bigger hole, I listen to the lows mainly.
Or should I have like 40" lol.
Looked on Torres, does anybody think I should tune to 25.27hz with a port area of 12.56" with my box volume of 4.1 cubic feet?I probably should have more port area but I don't want to cut a bigger hole, I listen to the lows mainly.
No. 30hz is already low. I wouldn't tune any lower.
@30hz I can get only get a few inches, looks like I'm forced to cut a bigger hole and put in bigger pipe, what a fuuck up.
wait what do you mean? I personally would tune between 32-34 but that is because I listen to more than just rap. I am not sure if that is why you are tuning so low
To get the right amount of port area I have to cut an 8" diameter with 23" length of port, that will give me 50sq" area tuned @33hz
Kicker 46CSS654 CS Series 6-1/2" component speaker system chose these for the front chanel Kicker 46CSC654 CS Series 6-1/2" 2-way car speakers...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
521
807
daveishome
daveishome
Canada
daveishome
audiobaun
    May 19, 2024
    May 19, 2024
