? about adhesives
azimuth
funded*by*soros
9,662
Denver, Co
planning a new system for my s10 using some plexiglass, so i need the inside of the box as clean as possible. i will be using a clear acrylic tube for the port, which will be pretty long. above 30 inches, requiring a bit of bracing for it. i usually use either gorilla glue or loctite power grab to adhere aero ports to the braces, but that stuff does not dry very pretty, and the clear tube will almost amplify the ugly glue. question: what is the best glue for gluing acrylic to mdf bracing, drying as clear as possible? and before i hear "super glue" or "crazy glue", i've used a couple different ones, and they fail.
use clear silicone, in the paint section of home depot for like 2 bucks a tube. should do the job. and some silver screws instead of black i would suggest for less of an eyesore
i use 0 screws on anything. i take that back. i will use them on the inside of a double baffle, but never if they will be visible. i know clear silicone has some adhesive, but will it glue acrylic to mdf solidly? 1500 rms won't be easy on the box.
Horse semen is an excellent adhesive and holds up great under extreme situations. I think I have some left over that I could send you if you cover shipping...
really!?! i really need some. here's the address i want it sent to:
Guenrich A. Avanesov
84/32, profsoyuznaya ul., 117810 moscow
the glue used on pvc pipe does dry almost clear, but dont know if it would hold on the mdf part of the equation. can you paint the other types of glue???
maybe a black adhesive?if you were very diliberate about how you apply it you could get good results, i know 3m windoweld is very solid when it dries, just an idea
azimuth
funded*by*soros
azimuth
Denver, Co
RAM_Designs
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
