Alpine i-Personalize help crossovers/parametric EQ
  • 2
ToxicAcoustiks
Hey guys,
So heres a basic run down on my setup right now, all 4 speakers are ran off the deck for now, I'm getting an audison lrx4300 4 channel soon and the fronts are going to be changed, but this is what I'm working with for now:
deck: alpine cda-9833
front speakers: 4" morel dotech mkll components (Frequency Response: 50-22000Hz - Crossover Point: 1800Hz 6dB/octave)
rear speakers: 6 1/2" powerbass 2XL-60C components (Frequency Response:
59Hz-20kHz)
sub: 1 12" DC Audio Level 4 dual 1 @ 800wrms-900wrms @ 2 ohm
Heres what I got the setings at right now, let me know what you think:
You don't have any lowpass filter set for the sub. With the slope turned off, you're going to be feeding it full range. If you're running a mono amp, it'll probably only go up to 400 Hz or so, but that's probably too high for a decent sub stage. You'll probably want to set it at 12 dB/oct. The i-Personalize feature is pretty neat that you can do it all online, burn it to a disc, then "install" the settings on your HU, but you're probably better off adjusting by ear while you're in your car. I tried out the i-Personalize one time for my 9855 just to see how it worked. I had much better results setting everything the normal way.
No problem. By the way, nice deck. I've always liked the 9833, 9835, 9853, and 9855. I've only owned the latter 2, but they're all very nice decks with a ton of tuning options, plus they're 3 way capable.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
241
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
559
Bump, somebody has got to want brand new merchandise at crack head prices. I'm willing to wheel and deal.
14
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
ToxicAcoustiks
ToxicAcoustiks
Brampton, ON, Canada
ToxicAcoustiks
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
