Alpine IVA-W200 & PXA-H701: ? for owners
plumpjack
Hey guys,
I just installed my PXA-H701 last night after being frustrated with the lack of control on the W200...now I'm frustrated by the amount of control on the H701! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
For those of you who own one or know about them... do you use the MX settings? What do they do? Are they just dynamic range compression? And what is the difference between 1, 2, & 3? It doesn't appear to be in the manual.
Also, can you use the Graphic EQ and Parametric at the same time? It appears that one turns the other off. I was going to use the Graphic EQ for correction and the parametric for listening preferences.
Lastly, from what I'm seeing the unit can only control 2 front sources, 1 rear, 1 center, and 1 sub. If I wanted a 3-way active setup in front would I just ditch rear speakers altogether (had thought of keeping them for rear fill)? Any suggestions?
Thanks in advance,
plumpjack
Uhhh, completely wrong on using the center source for the hights. That's a summed R+L signal.
When you say 3 way active, do you mean tweet, mid, and sub. Or tweet, midrange, midbass, and sub. H701 can do both very well.
You have to choose between graphic and parametric for the EQ.
Hey, Thanks for the reply. I meant tweet, midrange, midbass, & sub.
Thanks!
-plumpjack
So today I picked up this alpine unit for what I thought was a steal (I guess it was cause I only paid 120$ for it) it came with a mile of wires...
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
496
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
707
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
plumpjack
plumpjack
San Diego, CA
Hintzyboy
