Amp advice for Polk MM1240 under $300
The MB amp suggested before would be a good choice, and if you want a small powerhouse, you could go with a Massive N3 (it puts out 700 watts @ 2 Ohm).
It also lowers the amps efficiency and raises the current draw.
627
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Jayh9797
Jayh9797
Tx
fire_mike
maylar
    Jun 2, 2024
    Jun 1, 2024
