macsdad 10+ year member
boom-boom
ok, then how can one be sure he's not harming anything if they don't have the tools to properly set? serious question, not sarcasm.
oh wow.sometimes the clipping is not audible. usually, without a dmm or scope, setting your gain at less than half will be ok....and no bass boost.
If the sub is damaged then it is user error not from the lack of break in. There is the off chance there is a defect in the subwoofer itself, but that would be there now and cause issues regardless of the method in which he plays it.so all you people telling him not to worry ready to pay for a recone if something happens? Laminated spiders tear easy, There is zero problems that will arise from breaking your sub in for a day or 2.
Never use bass boost. Prior to installing any of your gear, it would do a lot of good to read up on how to set up your amps and enclosure information. Then you can move forward with installation. As long as you learned from your research you can use the sub from day 1 how you intend on using it. No reason to "break it in".So where should I set it at if you think? And how long til I can pump it full with bass boost?
Of course not. I'm just assuming that AQ takes the time to test all of their subs to pass a QC inspection. If they pass the inspection, then they should be good to fine at their rated continuous power. I mean, it's obviously possible for a sub to get past QC, but you can always say that you were breaking the subs in when they experienced failure.so all you people telling him not to worry ready to pay for a recone if something happens? Laminated spiders tear easy, There is zero problems that will arise from breaking your sub in for a day or 2.
No. Are you referring to the subsonic filter? Or the low-pass filter? Or something else?Oh and should I set my amps bass frequency at 34hz being that's what my box is tuned to? If you guys could give me some good spots to put the knobs that would be nice.
That's a pretty large blanket, there. You're very wrong, too.sometimes the clipping is not audible. usually, without a dmm or scope, setting your gain at less than half will be ok....and no bass boost.
No. Your signal is like a sine wave, constantly moving in that pattern. When you're trying to send a clipped signal to a speaker(sub), the wave is no longer rounded, but square. The square wave creates excessive heat and eventually damages your sub, regardless of the power you're giving it.Clipping is like where your music gets cut off by bass or somethin like that? I saw a diagram from it buy I didnt really understand it tho. If someone can make it simpler for me to understand that'd be kool.
Forget about bass boost altogether. If you want to be extra careful(not a bad thing), then set your gain lower than you normally would. Depending on your head unit's preamp output voltage, you might be able to get a decent amount of output with having the gain set as low as it can go, and you won't need to worry about blowing the sub.So where should I set it at if you think? And how long til I can pump it full with bass boost?
There's no way to be sure, for the most part. The best way to guess(and it is guessing unless you set it with a proper tool), is by looking at your head unit's preamp output voltage, and setting the gain to match that as closely as possible(gain settings are usually labeled as input sensitivity, with the low side being the highest input voltage, and the high side being the lowest voltage; it's often something like 5V-.2mV). If you have a head unit with 4V preamp outputs, try to set it near where 4V would be.ok, then how can one be sure he's not harming anything if they don't have the tools to properly set? serious question, not sarcasm.
Why no bass boost? Isn't it there for a reason? Where would I find some info? I doubt anyone has the exact same setup as me.Never use bass boost. Prior to installing any of your gear, it would do a lot of good to read up on how to set up your amps and enclosure information. Then you can move forward with installation. As long as you learned from your research you can use the sub from day 1 how you intend on using it. No reason to "break it in".
Gain - min-maxWell, that blows.
After bein broken in, can it take like 1-2db's of bass boost? Like use it sparingly and not abuse it? Or ABSOLUTELY not at all, not even 1db of it?bass boost induces clipping, clipping causes the voltage to spike and stops the cone from moving correctly making the sub over heat.
What is your enclosure tuned to? Your Volfenhags(if they were in a ported box) were probably tuned too high, resulting in a peak in the higher frequencies.Gain - min-maxLPF 40-180hz
Subsonic off-50 hz
Bass boost freq 30-80hz
Bass boost 0-12db
Ok those are my settings.
I have my gain up around 25% right now and I'm definitely happy! But the best has got to come right? Can I run at 25% gain to break it in a week or two an that will be ok? What's the maximum gain i should run before it gets dangerous? After its broke in of course.
Also I'd there are any suggestions on the other ones please share, I notice these hit medium and low frequencies much better but not the highs. My volfs actually hit btr on highs. Any idea why? Love the ways these sound but if theres something I can tweak to make it all sound gOod then I will!
I'm trying to help you, but it seems as if you not understanding or readig what has been posted.Gain - min-maxLPF 40-180hz
Subsonic off-50 hz
Bass boost 0-12db
34hz and my volfs were in a sealed box. May I ask can you please answer the gain questions, that's a big thing for me cuz I turned the gain from like 20 to 25 and it made a huge difference lolWhat is your enclosure tuned to? Your Volfenhags(if they were in a ported box) were probably tuned too high, resulting in a peak in the higher frequencies.
I understand. I just wanna be safe with breaking it in. What would be your suggestions to put the gain on then if breaking it in isn't a thing to do. Should I post this thread in the amp tech and it would be better?I'm trying to help you, but it seems as if you not understanding or readig what has been posted.
1. There is no need to break the sub in. You gain no extra power handling or anything other then a softer suspension, which happens no matter what.
2. There is an amplifier tech section on this forum with helpful info. Read through that before you do anything else with your setup.
3. No, do not use bass boost. There is no reason to even want to use it if you are setting everything up properly.
4. Research!!!! If you ate not sure research again. If you still don't get it, then stop messing with it and pay some one else to ensure things are done correctly.
