Lonnie 10+ year member
6'6 White Giant
OK well I am limited on what size battery I can put up front due to the area for the battery being so small. SOOOO im stuck getting a big one with a isolator in the trunk or 2 small batteries...1 up front and 1 in the trunk.
Not really wanting to spend more than $200 on a battery. EVEN THEN thats a bit much...but I understand you get what you pay for. Was gonna get a stinger battery off of someone on these forums for $110...but apparently hes not getting anymore. Not sure how big of a battery I should put in the trunk. Was considering a HC1400...not sure if its big enough though.
Currently running 1500 rms @ 1 ohm to 2 12s...soon to be putting a 4 channel amp in car that will probably be around 300-500 rms for comps. Will probably just run the comps off of the battery up front though...So I dont have to get too big of a battery for the rear.
SOO yea..what size of a battery should I put in the trunk? Currently got a cheap Wal-Mart Everstart 600 amp lead/factory battery up front with the big 3 and still getting slight dimming. Not extreme...but still enough to where I dont like how it looks on the outside when I push my subs. Car has a stock alt with 105-110 amps.
So yea...any advice? Other than taking a shotgun to the battery upfront since its from wal-mart //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
