N2 is correct, most likely a low impedance. If you ran the 2 10's in series you'd likely be fine on the fuse. Bazooka amps aren't well known for their quality and the lower quality the worse their tolerance for low impedance wiring. Disclaimer though, If you're not sure what the values on the impedance or what model each of these things are I'm going to give a firm recommendation that you research it at least a little bit, car audio is fun and if you don't care about the equipment it's no big deal to experiment, but you at least have to know enough to match fuse ratings, wire gauges, and grounding solutions to the power the amplifier is taking because electrical fires are serious business.
