box size?
  • 5
rdlyn13000
i'll be at my first comp Sept. 16, Im running a 12-zv3 off an saz1500 in a nice music box currently. I through it on a meter quick and did a 142.63 without any testing or even trying anything. I would like to build a burp box this week and see what I can do. My car was peaking at 34 and 37 in the music box, its a 99 Saturn 2 door. Im thinking of facing the sub in the car with a side firing 6" areo port. Im unsure what size box I should start with? And if it should be rectangle or square or??? Any helps appreciated Thanks
thanks, any idea on a dimensions? Also I may be bringing an saz3500 to the show...
go download the torres calc and play around with it. honestly, I would talk to anton though. the guy knows wtf he's doing when it comes to these sundown subs.
Just google torres calc? I did talk to Anton and he just kinda said build something and test then go from there which is what I plan on doing. Im just kinda looking for a basic start off point. I guess im not that good at figuring out what the actual measurments are for say 2 cube box?
google torres calc. play around with it until you find the desired dimensions. ps, buy my treo ssx 12... 4" of excursion.... $200
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
rdlyn13000
rdlyn13000
White Bear Lake
mylows10
    Jun 1, 2024
    May 31, 2024
