cant decide how much power for 9515g dd
BigSix
Whippin the Bass
2,348
Austin,Tx
I will be picking up my 9515g dd sub in a couple of weeks from now and plan on build the box to DD's specs 5 cubes at 37 hz...going in a jeep wrangler...also upgrading the stock alternator from a 90 amp to a 180 amp, and will be doing the big three and will have two yellow tops batts. Amp wise i have been looking at sundown 1500 vs the sundown 3000. I love bass just as much as the next bassfreak on here and dd tells me that to see her true colors keep it above 2k watts.....is the sundown 1500 enough power with the enclosure or should I be looking at 2k amp and above...this is for a daily driver btw
thanks for looking and appreciates all replies
BigSix
in the future i plan on getting another 9515g.....so i guess it would be in my best interest to get a 3000......can the sundown3000 be played at .5ohm???
if you're not an idiot.. and have the electrical system to back it up. lots of amperage there.
Well im upgrading the alternator......doing the big three and will have two batteries..... have one yellow top...might get another one or buy two kinetiks.....not sure yet havnt really don the research and have a couple of runs of 1/0 wire.....
Man. We all have had our share of good and bad on here. Ive deff. had my share for sure.. LOL. It all works out in the long run. Excellent to hear...
653
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
We still need to know what amp is having the issue, make and model. Some mono amps only have 1 preamp input and the other is a output.
BigSix
Whippin the Bass
BigSix
Austin,Tx
Papermaker85
    Jun 1, 2024
    May 31, 2024
