Chevy Silverado back seat dimensions anyone?
  • 2
Lil_KB
Louisiana
I'm picking up my new truck before the end of this week, 2001 chevy silverado ext cab. What is the depth I have to work with on the back seat? I want to start on a new design tonight and I need to know. Whats the max depth where you sit?
If it isn't much trouble whats the total max dimensions for laying a box on the back seat. Probably everything upfiring.
I have a thread here somewhere with some details, not much, but some.. Box dident turn out 100% as planned, and I still have not finished it yet. I am going to be trimming it more to make it fit, and ended up going with different subs, so its all cool..
Width 54"
width of center hump 16 1/2"
height of center hump 3 1/4"
Those are the dimensions I have that you can use, my other dimensiosn are made for my wants/needs which included the box stickign out about 2 more inches than you may want(to increase volume a little more).
Hope it helps a little.
-Lurius
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
You need check connections at battery. You Can Check with a DMM of the Amperage at the Alt while running , and check the battery in the morning...
4
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
777
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Lil_KB
Lil_KB
Louisiana
Lurius
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
