Comps to run active off Zed Draconia II?
cdt es or hd lines ,either will be fine and sound great with that amp .also if you wanna spend a bit more cash ,look at dls components ,then hit me up for prices on either sets
You'll have a huge advantage of going active in matching your drivers piece by piece. I've been doing similar research and been back and forth on a few ideas. What I think I've decided on are these paired together:
Tweeters:
Vifa XT25BG60-04 1" Shielded Dual Ring Radiator Tweeter 264-1012
Woofers:
DIYCable.com : Intro » Home » Exodus Anarchy »
-OR-
Dayton Audio RSS210HO-4 8" Reference HO Subwoofer 4 Ohm 295-458
There's tons of shootouts on DIYMA for reference and that's pretty much what I'm using. Good luck hunting, but the choices I mentioned above should go great together on that amp.
Ty for the suggestions so far.. Please keep them coming... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I do have a question tho, most comps are 4 ohms per side (tweet + mid), what is the load my amp is going to see per channel going active? 8ohms?
Without a DMM, it's hard to know. If you start going down the hunt for raw drivers (which is what I'm suggesting), it'll be listed clearly before you purchase. All of my links are for 4-ohm drivers.
Vifa tweets are very nice, but might want to consider the small format version as ring radiators need to be mounted VERY close to on-axis.
and x2 on getting raw drivers. Do some reading on diyma, lots of proven combos for any price range. PE and Madisound should have whatever you decide on...
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
3K
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
9
The install looks very nice and clean for sure. Thanks for sharing the pics as well as your experiences
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
seatown1two
seatown1two
Edmonds, WA
mlstrass
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
