DD M1B or American bass PH-4000MD
  • 4
u seriously thinking of doing that?
//content.invisioncic.com/y282845/emoticons/slap.gif.87520e8ca8e90076ac30e777c0de5331.gif
Dont know yet? //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Right now I have a DD M1B and just looking for some more power, would this even be worth the swap out? any help is greatly appreciated
i wouldnt hesitate to swap , you will notice a difference. i had the ph4000md and a dd m1a1 iirc is 1400rms @ 1ohm . and i say imo the american bass will put out more power then the dd you have now. ph4000md ran @ .5 ohm no problems . got a little warm thats all very easy on electrical as well. hope i could help bro
Edit : just noticed the dd is rated at 1900rms @ 1ohm. so the two amps you compared are more then likely going to give you the same results in the end
the DD is rated at 1200 @11.9volts not 1900rms
lol i knw it . someone mentioned above it does 1900 so i thought i was wrong //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif . in that case i would do it and would nt think twice .it does rated and some . .5 it was around 2500rms
im just saying we recently clamped a pair of the 2500 and they barely made over 1100 so i doubt the 4000 even does 2000 and they are rated for 14.4 where as the dd is rated at 1400w at 1ohm and 11.9v, the 1900w clamp result was for 1ohm and 14.4 so yea dd all the way.
the ab is a solid amp but i would pick their big bro everyday even when comparing subs dd is the original with the best parts
at what load? after rise im right at 1.5ohms
Clamp results :DD M1b
Voltage drop: 13.5v
49.1 Volts
45 Amps
49.1 x 45 = 2209 watts
49.1 / 45 = 1.08 ohms
The "1500" watts amplifier CHALLENGE!!! - Page 5 - Amplifiers - SMD Forum
dd m1c - Soundpressure.com Forum
I guess it depends on who clamped..I have seen the lowest of 1900 @ 1ohm and 2 clamp tests claimed 2200 @ 1 ohm...shrugz..take it for what it is, I would stick with the reliability of the DD....now, if we were talking the VFL 150.1, or something like that, well..
Clamp results :DD M1bVoltage drop: 13.5v
49.1 Volts
45 Amps
finally we agree on something
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
4
nate56
nate56
colorado
quackhead
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
