DLS a6 Fan install
  • 1
Hey guys, new user, first post. So my deal is that i have a couple old school DLS A6 amplifiers that i got through my uncle from his pawn shop and they are in near perfect condition. Anyways i noticed when running them at 1 ohm they get pretty hot and they both have an internal fan so one side of the amp tends to stay a little cooler than the other but i want to run a couple fans to blow some air over the fins. This is what i know: the amps have a built in "fan out" terminal where the second power in/ground in is. I know that the max amperage draw it can handle is .5 amps. I know that the amp will turn the fans on if it gets too hot and the temperature dictates the speed. What i dont know is how to wire the fans. Obviously they have two wires, power and ground. So im not sure if the power wire goes to the one fan out terminal and i ground the other wire to the car or add it to the amp ground i already have. I found an old thread regarding an a6 fan install but there were no clear instructions for wiring. Thanks in advance for any help!
Never mind, I figured out that the positive lead goes into the fan out terminal and just ground the other lead. However, this output only supports up to .5 amps so I'm thinking I should go with a spdt relay that way once I install my other amp I can always add on more fans and possibly leds without worrying about excessive amperage. Everything should be below 5 amps anyway
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
There are all kinds of Ideas out there by a search on the internet these days. Find the one that works for your situation and budget and...
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
611
paulmarsh1222
paulmarsh1222
Brooksville, Fl
paulmarsh1222
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
