Eclipse 8053 goes as high as 76 volume mine will play up to 51-55 than sounds wack
rasta4life
My question is what my title says I have a eclipse 8053 when I play past 53 or more it starts to sound worse even though I can go as high as 76 should I lower my gains so I can go a little higher and what volume do you have to where it is loud but not to the point where it starts sounding bad.thanks
Just because it goes to 76 doesn't mean you're supposed to turn it up that high. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
What's your equipment? Chances are once you get to that point either the internal amp is starting to clip, or it's sending a clipped signal to the speakers.
Basically, once it sounds crappy, turn it down.
Amps can only put out a certain amount of power. Whether or not you set your gains to maximize that power at 30/76, 50/76, or 76/76 volume, adjusting your gains to where they don't clip until 76/76, won't make a difference.
What you need is an external amp to power your speakers //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
The 8053 is a dead head, no internal amp.
What's your equipment? Chances are once you get to that point either the internal amp is starting to clip, or it's sending a clipped signal to the speakers.Basically, once it sounds crappy, turn it down.
Actually, adjusting your gains to where they're as low as possible is hypothetically the best situation since it lowers the chance of noise getting into the system. I personally use the 8053, and have been for 3 years or so(8053, then 8443, and back to 8053), and that radio will not send a clipped/distorted signal. So his bad sound issue is either some sort of defect within the HU, or the gains are too high on the amp and he's clipping the signal there. With my amps, I have the gains turned all the way down and never need to turn it past 65-70 out of 80.
It sounds like you either need more power or speakers that can handle the power that you have...or you just need something that can get louder because you're trying to reach a level that your speakers cannot get to and still sound good at the same time.
What specifically are you running?
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
7
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
4
817
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
rasta4life
rasta4life
New Mexico
RAM_Designs
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
