Engine Noise
  • 1
When you say engine noise I'm assuming it's an annoying whinning sound that gets more intense when you accelerate. This is a common problem called alternator whine. This can be a frustrating problem because often times you have to retrace all of your wiring. There are in line filters that you can buy to help reduce the sound or even eliminate it. The most common cause for this problem is a signal/low voltage cable crossing a power cable. Make sure that your RCA cables and speaker wires are as far away from your main power cables as possible. another possible cause could be a bad ground somewhere in your wiring. make sure all connections are good and that your wires aren't touching any bare metal where they shouldn't be. Often time this takes a lot of trial and error in the wiring to fix the problem.
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
iceberg
iceberg
Uranus
audiobaun
    May 19, 2024
    May 19, 2024
