FLV to DVD Converter for Mac
  • 1
cjzcoc
FLV to DVD Converter is designed to help you convert FLV to DVD. With this converter FLV to DVD, you can easily convert FLV files to DVD videos and burn movie DVD, that can be played on any DVD player.
There is a professional timeline panel provided by FLV to DVD Converter to help you edit videos easily and precisely. You can trim video, merge videos, rotate video, add titles and credits, and apply audio and video effects.
FLV to DVD Converter also allows you to customize DVD chapters and menus. You can select NTSC or PAL standard, intuitively adjust the DVD video quality, choose aspect ratio from 4:3 or 16:9, and other settings.
If you are looking for a free FLV to DVD converter, please have a try with this FLV to DVD Converter.
This FLV to DVD Converter works on Windows XP, 2003, and Vista, if you are Apple Mac OS X, please click FLV to DVD Converter for Mac.
Key Features of FLV to DVD Converter
Convert FLV files to DVD video
All the FLV video files downloaded from video sharing web sites are perfectly supported. You can directly convert them to DVD videos and burn movie DVD, playable on home DVD players.
Adjustable DVD settings
FLV to DVD Converter allows you to create NTSC DVD or PAL DVD, adjust video quality from 4 quality levels, set video aspect ratio from 4:3 standard screen or 16:9 wide screen.
Edit FLV video before burning
Professional timeline panel is provided to facilitate your editing. You can easily trim video to cut unwanted parts, join several video clips and output one file, apply more than 50 audio and video effects to your movies.
Create DVD menu with ready templates
You can split video into chapters and create your own DVD menu. Select from plentiful menu styles suitable for all occasions, and customize background pictures, chapters.
Directly burn movie DVD after converting
FLV to DVD Converter firstly convert FLV files to DVD video, and then burn movie DVD, supporting all sorts of DVD discs. You just need to input a blank DVD disc and click Start Burning.
Easy to Use
All the video converting, DVD setting, menu creating, and DVD burning can be intuitively accomplished with several clicks. To convert FLV to DVD is easier than ever.
YouTube to DVD
Mac YouTube to DVD
I would recommend to get on F.Book @ Old School Stereo and run a Want To Buy thread there. Im sure someone is hoarding one, maybe even a BNIB one...
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
cjzcoc
cjzcoc
Beijing, China
cjzcoc
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
