Frequency Settings?
'97Z71
I have a pair of Boston Acoustics pro6.5 seperates running off a JL Audio 300x4, right now the frequency cut-off is at 120htz, if i want more midbass could i lower it to 100htz without distortion? Also would it be better to do this if there were more power to the speakers? If so, would using a 300x2 JL amp be a good inversment for running these front speakers? Thanx
I am not sure about Boston, buut they are pretty solid. I have my MB Quart 7 inch components set at 75 hz, and they still play flawlessly. I would think Boston's can play down to 50 hz with the clean powerful full watts the JL 300/4 amp can supply them with, I use that exact amp for my Quarts!
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
702
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
Trust your ears. If your soundsystem rolls off early without a sub, then cutting high Can be beneficial. Most cut around 80hz, but I have had good...
'97Z71
'97Z71
Sacramento
BlackSunfireGT
maylar
    Jun 2, 2024
    Jun 1, 2024
