FS/FT: Phoenix Gold ZX475Ti
  • 3
WashYourWinky
The Pilot
Cosmetic 7/10 Mechanical 8/10
I'll get the bad out of the way first. There is some distortion when turning the frequency control knobs, the three blue led lights don't work. Minor rust, know issue with these amps.
Other than the distortion when messing with the frequency control, the amp functions as it should.
Specs:
ZX475Ti
Into 4 ohms Stereo @ 12.5 Vdc (IASCA/USAC) 18 x 4
Into 4 ohms Stereo @ 14.4 Vdc 75 x 4
Into 2 ohms Stereo @ 14.4 Vdc 150 x 4
Into 4 ohms Bridged @ 14.4 Vdc 250 x 2
Minimum Speaker Load, Bridged 2 ohms
Minimum Speaker Load, Stereo 1 ohm
Recommended Fuse Size, Stereo 4 ohms / Stereo 2 ohms / Bridged 60 / 80 / 80 amp
Continuous Current Draw @ Full Power * 60 amps
Peak Current Draw @ Full Power ** 85 amps
Dimensions, Chassis (inches) 15.00 L x 9.00 W x 2.25 H
Dimensions, Overall (inches) 16.00 L x 10.00 W x 2.25 H
Total Harmonic Distortion
Signal to Noise Ratio (A-weighted) > 100 dB
Frequency Response +/- 1 dB, 20 Hz to 20 kHz
Bass Boost 0 to +18 dB @ 45 Hz
Crossover Frequency Range 40 Hz to 8 kHz
Crossover Slope 24 dB per octave
Input Sensitivity 200 millivolts to 6 volts
Input Impedance > 30 kohms
Input Voltage Range 0.2 volts to 6 volts
Power Supply Operating Range 10.5 Vdc to 15.5 Vdc
Typical current draw at idle
Looking to get $170 obo shipped in the lower 48
Trade for 1000w at 1ohm, a decent d4 or d2 10" sub, a head unit, 6.5" comps, make me a trade offer!!!
Will ship USPS.
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
389
I just read the other post about this Bass Cube. IMO, it sounds like a signal leveler with adjustable Q. For that you can just use one of the many...
  • Locked
You said, "one of." How many do you have? I'm guessing that you are keeping the best one(s).
4
5K
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
