FS: Old School Boston Acoustics GT-42 4 channel Amplifier
gymdiver426
This is a 4 channel amp i was using for my door speakers in my 2010 Mazda 3. I'm currently working on an active 3-way system build and need to sell my old systems components to get the funds for this build. I have had no issues from this amp, it is however old and a little worn (scuffs and scratches).
U]Specs:[/u]
4-Channel High Current Amplifier
2 Ohm Mono Stable
Advanced cooling allows varied mounting positions
Adjustable feet for varied mounting surfaces
Screw-down security cover protects tuning controls
Terminals accept bare heavy-gauge wire
RMS Power Rating:
14.4VDC:
100 watts x 4 chan. @ 4 ohms
150 watts x 4 chan. @ 2 ohms
300 watts x 2 chan. @ 4 ohms
450 watts x 2 chan. @ 2 ohms
12.6VDC:
75 watts x 4 chan. @ 4 ohms
120 watts x 4 chan. @ 2 ohms
220 watts x 2 chan. @ 4 ohms
350 watts x 2 chan. @ 2 ohms
Adjustable input sensitivity: 0.2 - 5 V
Variable High-Pass Crossover: 20 - 350 Hz (12 dB/Oct)
Variable Low-Pass Crossover: 50 - 350 Hz (24 / 12 dB/Oct)
Variable Q Control: 0.7 - 1.2
Power and Safe LEDs
Recessed RCA Inputs allow clearance for tight mounting locations
Optional subwoofer level control not included
Dimensions: 22" L x 9" W x 2-1/2" H
$150
$20 Shipping cost
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
gymdiver426
gymdiver426
South Florida
gymdiver426
    Jun 1, 2024
    May 31, 2024
