gain settings
  • 3
cb4goals
13
AL
i recently purchased a fi ssd 12 and installed it today. i have a rf 700s 2 channel amp rated for 175 rms @ 4 ohms or 350 @ 2 ohms. i have the amp bridged going into the sub. my question is how should i adjust the gain settings? the only way to adjust them is two small screws near the output of the amp. should i just adjust it till it sounds right? and how do i do that when there are two seperate places to adjust the gain for one speaker?
I posted this under another thread but here it is again:
1. Turn off all EQ settings on the deck (Flat, no crossovers on)
2. Turn the volume on the deck up to 3/4 volume.
3. Get a good quality CD or song off your iPod and play
4. Adjust gain slowly until you start hearing distortion (you should be able to tell with it at 3/4 volume)
5. Once distortion is reached, turn down slightly until it goes away. (Slowly turn each side of the gain when you are bridging.)
Another way to tune is to use a DMM and using the same steps listed above (except you should be playing a 60 Hz tone) but actually disconnect the sub from the amp and measure the voltage on the output using the Volts AC setting. Example: If your sub is 4 ohms and needs 175 RMS then you would adjust the gain until the voltage hit 26.4 Volts AC
Also type of deck, type of sub, and type of vehicle would help.
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
846
I hold firm on the deposit in all situations 😎
9
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Voltage for the signal? What does that mean? Electricity isn't measured in purpose. Gain is a characteristic of a circuit. You aren't adjusting...
20
6K
cb4goals
cb4goals
AL
qkassidyw
