• 4
wheather im driving, in idle, or on accessory mode my amp just randomly stops producing output to my subs. the light doesn't even twitch when this happens, and everytime it does this I have to take me faceplate of my reciever to turn the amp off, and then ill put it back on, and it turns on, my amp will turn back on and I have to gradually turn my volume up, one notch at a time and at a barely audible level, such as 9 out of 45, then they will work, but will randomly stop again, and will have to do this 3-4 times over a 10 minute period, please hellpppp!
Try and run an mp3 player directly to the amp and see if you still have the same problem.
If it no longer dose it, then you HU is shot, if it dose still do it, then it may be the amp.
I have seen that before with that series of amps. It's likely the amp. Bad solder joint(s). The other one would work fine once you turned the volume up high enough for it to "turn on".
Shoulda stuck with kicker???
244
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
905
Thank you for the help. Now I finally understood :) Bass working fine now :) Life back to music ;)
allaboutKicker
allaboutKicker
Southern IL
keep_hope_alive
audiobaun
    May 19, 2024
    May 19, 2024
