Help with amp/sub decision
  • 3
a00179204
I have a 102 amp alternator, and I'm looking for an amp sub combo. My ideas
Ported gcon or icon 12 or 15 (the gcon 15 qts says it's more for sealed but I really want to port)
Jbl ms500.1 800wrms and get a gcon
or ppr 1000.1 1100w rms and get an icon
What would sound best. I listen to mostly hip hop
Thanks all
The MS500 is not 800. That's dynamic and doesn't matter.
I would do the NVX version of the PPI and the GCON ported.
What you listen to don't matter either. Done right it will play anything.
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
I still have some Old school stuff that I really enjoy to this day. I still swapp amps and other gear I have from time to time and run for a...
17
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
a00179204
a00179204
boston,ma
a00179204
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
