how far away can x-overs be from speakers
2008screw
How far away can you place the passive x-overs from the actual speakers and is there any signal loss or any other problem if they are far away?
I ask because I have not found a suitable place to stash them close to the door speakers. I was thinking about placing them close to the amps that will be running them mounted on the back wall of my truck behind the rear seats.
I prefer my passive crossovers to be very far away from me...like in a landfill //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
like i said, place them wherever is most convenient for you. it does not matter. absolutely nothing wrong with placing crossovers in your trunk. you will not lose any signal, why would you? crossovers do what they are suppose to do, filter frequencies and thats it.
I thought there might be some sort of loss due to distance like there can be with power wire.
If there is not, then awesome, I do not have to worry about it.
Thanks for the help guys.
I always put the xOvers in the doors.
Do you mean in the actual door on mounted on the interior? If you put them on the inside, i dont think you should keep them their, this is because they can get wet and rust and bad things.
Agreed and Brand X doesn't exactly have the greatest rep to begin with in the car audio community for a decent product.
4
939
I didn’t want to mess with my daughters EV, so I just made a small stand alone with 6x9s. It’s around 75 watts rms and fairly loud actually. Real...
8
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
Get a Wrangler and get naked (you know…the Jeep, not you…none of us want to see that) and you’ll definitely be heard coming. 😉
7
2008screw
2008screw
Vancouver, BC
Etac
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
