How to prevent rust on grounds
autoparts stores sell "battery connector protection" that is a dielectric/silicone mix. a great solution and it comes in small packs.
I use that on my batteries in my diesel and I've never had any issues. It sets up to a gel and the heat won't make it run. In the cab I do the liquid electrical tape(2 or 3 coats) because it dries and won't rub off. I paint a small amount of the spray on battery terminal protector in between the ring terminal, body panel, washer and on the bolt threads because moisture over time will travel up them from the outside.
Make sure the fluttering sound you are hearing isn’t something flexing. When I start pushing my subs, the sunroof sliding cover flexes so much I...
29
5K
fwiw... https://www.pasmag.com/technology/dash-kits-accessories/oxygen-free-copper-ofc-vs-copper-clad-aluminum-cca-cables
5
got it, thanks ill post some pics when we get to doing this next week he builds racecars and **** so i think he would have everything i need for...
10
knotdrummer88
knotdrummer88
Toledo, OH
tc300
