How to run a sub off a alpine mrv f505?
Not much help there, man. Noob just wanting a sub. Pointing me in the right direction would help, not just asking questions you can answer with your own eyes.
How can I answer the question with my eyes?
If I had to guess I would say that amp has popped fuses many times due to bad running conditions and the fuses were replaced with whatever could be found.
Before you try running a sub off that crappy amp that already blows fuses I would like to address what is causing that and fix it.
But since you are a know it all dikhole you can figure it out yourself
That amp does nto produce the power you need to run a sub.
Bridged it is rated at 130 watts x 1
It is an old amp and best suited for running the speakers that it is currently hooked up to.
Add a new mono-block amp and new wiring if you want to run a sub.
Also buy a pair of matching 25 amp fuses and put those in so it doesn't look so ghetto fabbed.
It's enough to run a sub. Will it have much output, probably not. Will it work, absolutely.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
Nwocrydad
Nwocrydad
Fort pierce Florida
Nwocrydad
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
