Keep it stock? Or low-end double din?
Mills561
BURR
I have an 02' Chevy Trailblazer that I'm in the process of dropping a system into.
Now about the headunit-- should I keep it stock? Or would it be worth it to get a cheap double din? I eventually plan on getting a Pioneer or Alpine h/u. But for now I just want to get the subs in, and save up for a high-end 2din.
What are my advantages/disadvantages? Would I have to buy anything to make my stock h/u capable?
Thanks.
If you want to keep your stock HU, you can get a Rockford Fosgate 3Sixty.2 Processor to convert the speaker leads to pre-amp for input into the amps and fine tune the sound. However, the 3.sixty.2 is pretty expensive, around $300, but a nice piece of equipment.
There are other processors that will do this, but the RF 3sixty2 is really nice.
You can pull that amplifier and take to an Audio shop and see if they will test it. Most shops charge very little and some will not even charge...
Go 150 Watts speakers or equal to your amps. 150 watts and up is your amps. That's the good rule of thumb.
The best thing you can do is make a solid plan. This way you won't be spending money twice and having to keep going back in add or replace parts.
27
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
339
Mills561
BURR
Mills561
Palm Beach, Florida
CRXBMPN
    May 18, 2024
    May 16, 2024
