kicker kx 1250.1 help
  • 2
blackMTXgold
PiMp MeMbEr
does anyone have experience with this amp, me and my friends are having trouble setting it, he has 2 12" L7s wired at 1 ohm to this amp, and its in a dodge avenger which has a stock amp powering the speakers, but with the cd player whenever you mess with the controls for the sub it affects the speakers also, and the subs arent puttin out hardly any bass, confusing digital settings for the gain and frequency on the amp, i dont know what to do, the subs arent loud at all, the speakers have more bass,
make sure the RCA outputs are correct on the H/U.
OR is this person using a Stock H/u with a spliced speaker output for RCAs BEFORE the speaker signal is taken into the stock amplifier for the speakers?
Out of those two for the money.. Id go with the Kicker. they still make great amps
937
blackMTXgold
PiMp MeMbEr
blackMTXgold
Waseca, MN
blackMTXgold
