Kicker Products???
I have used and still use L7s from time to time to compete with. Not for daily though. In the right box they do sound decent, but if you are buying new there is a lot better out there....
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
835
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
atlang3lo
atlang3lo
Atlanta, GA and Seattle, Wa
matt_bennett05
