Kicker Products???
I've owned a Kicker Comp12(the older kind), four 10" Kicker comp(the second to the latest-gen), the silver-cone 12" L5, 12" L7(one 1st-gen and one latest-gen) and installed two 12" Solo-X in my friends ride.
From personal experience Kicker subs are loud as long as you stick with L7 and Solo-X. I blew the Comp12 with 800 watts in my home theater but it took a long year, the 2-gen L5(silver cone blue lettering) tore a tinsel lead with 500 watts and so did the 1st-gen L7 with around 1100 watts from a Brutus 1606D. The Comp 10s are kind of anemic and doesn't pick up the low bass very well.
The latest-gen L7s are nice, redesigned tinsel wires stitched into the spider is a lot better than just hanging wire like the 1-gen L7s. The Solo-X, while doesn't have much SQ to talk about, gets SUPER loud. We have an USA-2000X powering the pair and they can definitely take more. The early-gen Comp and CompVRs(round, parabolic cone) sounds very nice for their pricerage and looks good, I overpowered mine like 3 times over but it took that much for a year before the coil started to make a faint rubbing noise.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
833
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
atlang3lo
atlang3lo
Atlanta, GA and Seattle, Wa
matt_bennett05
